how to delete instance with commvault api
  • January 10, 2024
  • 53 views
We are trying to remove the instance with API , however we cannot find any endpoints on the swagger .
Could you please guide us to deal with this.
Satish
Hello @mehers
Thanks for the great question! The following will allow the removal of an instance using API.
https://api.commvault.com/#6738b686-e2d6-4571-b82f-2b74db13de16
Hope this helps!
Kind regards
Albert Williams
