Instance Enable
  • July 26, 2023
  • 58 views
I am monitoring the subclients. I see the “enableBackup” in the api for the subclients but notice the job does not run when the instance is not enabled which I can detect visually from the UI but do not see an attribute in the Instance or InstanceProperties API. Is there attribute for the instance enabledBackup?
Best answer by Navneet Singh
@J-Rod
You can also use the below qscript and the same can be passed through the API as well.
https://documentation.commvault.com/2022e/expert/EnableSCActivityControl.html
https://documentation.commvault.com/2022e/expert/48597_rest_api_post_qcommand.html
dude
Forum|alt.badge.img+20
  • Community All Star
  • July 27, 2023
Forum|alt.badge.img+13
