Linux script output on workflow
  • Nov 18, 2023 5:44 AM UTC
  • 79 views
I want to run one script on linux  client, if success them trigger backup job, could you guide me how to select linux client in workflow?
Hello @xiwen
Thanks for the great question, I’m not sure if this is going to achieve what you are trying to do but may get you there:
https://documentation.commvault.com/11.23/expert/12759_pre_processes_and_post_processes_getting_started.html
Any further details and context around what you are trying to achieve will help us provide the best answer for you.
Kind regards
Albert Williams
Hello @xiwen
Kind regards
Albert Williams
  • Nov 20, 2023 1:40 AM UTC
Thanks for your reply, we plan to run Linux script to suspend application, if success then trigger Azure Intellisnap for the Linux host. Unfortunately, pre & post script doesn’t support Azure.
So looking for workflow option.
