Need an API endpoint to remove backupsets, clients and vmdk from filters
  • August 30, 2024
  • 70 views
Forum|alt.badge.img+8
I need an API endpoint to remove backupsets, clients and vmdk from filters of the subclient.
Commvault version 11.32.43
Hello @RandomCustomer
I found this API but it seems to be specific to File system as it does not list the “filter” as a request parameter.
https://api.commvault.com/docs/SP36/api/cv/SubclientOperations/update-subclient-properties/#update-subclient-properties
I would still give it a shot and see if you can get it to work as i don't see one specific for VM’s.
Kind regards
Albert Williams
Kind regards
Albert Williams
