Need to delete the VMs from content as well as it reappears
  • May 10, 2024
  • 71 views
I need the api to get the contents of the of the subclient and then remove/delete it from the content itself.
Hello @RandomCustomer
I Just saw you have opened a second thread about what you are trying to achieve.
I will talk to you about the issue there:
Please go ahead and mark this thread closed and we will talk on the other one.
Kind regards
Albert Williams
I’m not sure i 100% understand your question. Is there a single VM that you are attempting to remove and it keeps coming back?
Can you confirm if you are using the Java console located on the CS server or a remote console?
Kind regards
Albert Williams
Kind regards
Albert Williams
