no open approvals
  • January 19, 2025
  • 227 views
Hello
i would like retire client and job for that is in waiting status -
Error code: [19:857]
Description: waiting on user input [Retire agent [ DB -> Windows File System ] requested by [ admin ]]
Source: cs-vm, Process: Workflow
At monitoring - approvals no items here, no open approvals.
Pavel
Best answer by Pavel Banar
solved, two users at master group are required - you can not approve someself:-)
  • January 19, 2025
