Qcommand or way to retreive the Instance Size details per VM from the job details for a Snap Backup job
  • Jun 13, 2024 1:30 PM UTC
  • 86 views
Forum|alt.badge.img+8
I would like retrieve the instance size information for each VM for a specific job?
Is there any qcommand / API that i can use to get this info
Hello @alligator
Thanks for the great question. The way V2 VSA backup jobs work is that you will have a parent VM job but each individual VM will have its own child job. You should be able to use the following API on the child jobID:
https://api.commvault.com/docs/SP34/api/cv/JobOperations/get-job-details
If you are using the V1 agent then it will be 1 job with all the VM’s inside of it. If that is the case i recommend moving to the V2 agent.
https://documentation.commvault.com/2023e/expert/migration_of_virtualization_clients_to_indexing_version_2.html
Kind regards
Albert Williams
Hello @alligator
Kind regards
Albert Williams
  • Jul 10, 2024 7:50 AM UTC
Is there an API to get the VM Job ID from vsaParentJobID?
When i try to Get Job Details using the HTTPClient using the VSAParentJobID, its not yielding any results?
https://documentation.commvault.com/v11/essential/rest_api_get_job_details.html#sample-request
Without parentjobID how will i be able to query/list the VM job ID
