Server Retirement Workflow
  • December 19, 2023
  • 100 views
Forum|alt.badge.img+2
If the "Server Retirement" workflow was run on the wrong server and approved, how can the workflow be cancelled?
Best answer by Chris Hollis
@Jack COA
I’d expect there to be a workflow job in the job controller that you can kill.
Do you see one? If so, please kill it.
Otherwise, can you check the workflow job history and see if anything is recorded?
https://documentation.commvault.com/2023e/essential/viewing_workflow_job_history.html
Chris
  • December 19, 2023
I found this, https://documentation.commvault.com/v11/essential/retiring_server.html
The server in question is not disabled and backed up on schedule last night. Does this confirm the server is NOT going to be retired by the workflow?
Chris Hollis
  • December 19, 2023
@Jack COA
Chris
