snowflake
  • Jun 11, 2025 8:41 AM UTC
  • 172 views
JosserandM
Apprentice
Any early adopter program to backup snowflake around here ?
or private discussion about it to see if there any initiative on that ?
As far as I'm aware this is not on the roadmap. I also do not know other competitive solution that offer native protection for Snowflake. However, you can dump tables to a S3 bucket and protect the bucket using Commvault see https://community.snowflake.com/s/article/backups
To get this moving you for sure will have to raise a CMR or get your CCID on the list of an existing CMR.
Onno van den Berg
Forum|alt.badge.img+24
JosserandM
Apprentice
  • Jun 12, 2025 2:01 PM UTC
Thank you, yes I was aware about the dump S3 method but thx to propose it. My customer is looking for more embeded solution thx anyway !!!!!
