SQL Server TempDb
  • November 14, 2023
  • 243 views
Forum|alt.badge.img+2
Hello, I need to move CV SQL Tempdb to a different drive.
I’ve found in the documentation there is a SQL Server Relocate TempDb workflow, but I’m unable to find it on the CV store.
What I’m doing wrong
Thanks and regards
Best answer by casp
Yes, you are right. Just finisched to install the FR32 and the workflow is already installed
Thanks and regards
Scott Moseman
Forum|alt.badge.img+23
Have you checked to see if you have it installed already?
I don’t have an FR28 to check, but it came with my FR32.
Scott
  • November 14, 2023
Thanks and regards
