To display a Commvault diagram of own infrastructure
  • Jul 24, 2024 12:36 PM UTC
  • 192 views
Hello dear community,
Can you perhaps help me. I heard that Commvault has a way to automatically display the Commvault infrastructure in 2D or 3D as a picture. Do you know how to do this or is this information incorrect? I would be very grateful if you gave me more information about this.
That would help our employees to understand a little more of the commvault construction in our company.
Best regards,
Eugen
Best answer by Javier
Hi @Eugen ,
I’ve never heard of this feature before. I won’t confirm 100%, but I am pretty certain that is not something that can be done.
What you could check and may give you certain insights on the network configuration. Are the Network Topologies, which should show how the different clients,proxies,infra interconnect together.
  • Jul 25, 2024 8:21 AM UTC
Hi @Eugen ,
  • Jul 25, 2024 8:26 AM UTC
Hi @Javier
Do you mean, that the network topology on Commseve can be visualized better? If so, where can I find or see it in CommServe?
  • Jul 25, 2024 8:39 AM UTC
Not better, only the view available from the Commcell Console.
But that should give you a better understand of how things are configured and Client Groups linked to each other
