User Permission
  • November 28, 2023
  • 116 views
Forum|alt.badge.img+9
We are trying to create a role for a specific user that only needs to do remote qlogin from a linux client computer and triger a backup for the same client.
What will be the minimium required CV priviliges to do it ?
Best answer by Chris Hollis
@TNO
They’ll need entity association to the client computer with the Data Protection/Management Operations permission.
Chris Hollis
  • November 29, 2023
@TNO
