Virtual Lab OVA
  • Oct 4, 2024 9:23 AM UTC
  • 149 views
Forum|alt.badge.img+2
Just creating and testing The Virtual Lab
Everything works fine except deploying the OVA to have a proxy running
The OVA is not deploying and when I make it an OVF the same problem
So the question is : I can see it is a CENTOS server, is there runinng the rdp gateway solution on it
Then I can build my own proxy and have access to the restored server from an external network
  1. has anyone some details over this OVA template, about how to deploy it
  2. OR how this proxy is build, so I can build it my self
Thanks and Regards Gerard
Best answer by BosmannGJ
Find The Answer
  • Oct 4, 2024 10:45 AM UTC
Find The Answer
