VM Backup and restore workflow
  • Jul 21, 2023 5:50 AM UTC
  • 445 views
I am trying to create workflow for VM backup and restore.
I have used predefined workflow Demo_FileSystemBackupRestore and tried to modify it for VM.
Everything goes fine until it gets to restore phase where I get Error 0x303: Q_VIRTUAL_SERVER iDataAgent is not supported by this command.
Thanks for any suggestions,
Michal
Best answer by Damian Andre
Hi @Michal Antos -
The restore part of the workflow probably needs to be replaced with a qcommand and virtual server XML - you can get the XML by running a restore and then using “save as script” and put it into the workflow.
  • Jul 25, 2023 3:03 AM UTC
Hi @Michal Antos -
  • Aug 7, 2023 10:06 AM UTC
Hi @Damian Andre,
I was on vacation,
and thank you for pointing me out in the right direction, using ExecuteScript in Utilities I was able to run a restore.
