Commserve fileover replication probleme
  • May 18, 2023
  • 52 views
Forum|alt.badge.img+5
I have a problem with Commserve failover replication.
the job stops in the database restore phase with the error “received failed message for job [], phase [database Restore].
Can you help me please?
Best answer by Emils
Hi @Elmahdi Achraf
Thanks for reaching out.
Please ensure all pre-requisites and planning has been followed as per our documentation.
If you find you’re still facing issues, I would recommend raising a support case.
Emils
  • May 18, 2023
Hi @Elmahdi Achraf
