Commvault SQL plan
  • June 29, 2023
  • 43 views
Hi guys,
Is there any good reason to create a dedicated plan for SQL, or would it just be the as active the SQL option and specify the RPO?
Regards
Best answer by Scott Reynolds
Hi @cv_joel Many times separate plans are used as SQL or other databases will have different retention requirements, storage, etc so a separate plan makes sense. Also in some cases you might want to visually see a SQL plan just for organization or have different plans for different servers. It's a preference.  However, it is certainly not required.
