How do I assign barcodes to tapes in a stand-alone library?
  • April 21, 2021
  • 78 views
I have a stand-alone tape library and need to ensure that I utilize barcodes from the get go. How do I add them for each tape?
Best answer by Samwise
To add media identifiers to media that are associated with stand-alone drives:
1. Make sure that new media is loaded into the stand-alone library drive.
2. From the CommCell Browser, right-click the appropriate stand-alone library, and then click Stamp Media.
3. In the Stamp Media dialog box, enter the barcode number or a unique identifier for the media.
4. Click OK.
A message appears that tells you that the stamp media was successful.
5. Click OK.
The media is listed in the Default Scratch pool.
  • April 22, 2021
4. Click OK.
5. Click OK.
