About adding 1 node to HSX.
  • Aug 29, 2023 12:37 PM UTC
  • 122 views
bbilsel
Novice
Hi All,
We are building a Hyperscale-X environment for a customer. However, I received a question from my customer.
The reference architecture servers that are present are nearing the end of their life cycle. The processors on these servers belong to the 2nd generation.
Is it possible for me to include this server in my HSX environment if the next-generation reference architecture is released and I need to add one node to my existing platform?
Best Regards
Best answer by Collin Harper
Hello @bbilsel
For Hyperscale there are certain hardware that are approved for hosting. If the old hardware is listed here you should be able to use it.
Design Specifications for HyperScale X Reference Architecture - https://documentation.commvault.com/2023e/essential/132722_design_specifications_for_hyperscale_x_reference_architecture.html
Thank you,
Collin
Hello @bbilsel
Thank you,
Collin
