Best way to move storage policy from existing HS 1.5 to new HS X.
  • May 21, 2024 12:53 AM UTC
  • 87 views
We have just added some new Hyperscale X to our environment, and new disk libraries created.
I want to move/ copy some jobs with extended retention rule to the newly created libraries. Please what is the best possible way to do this?
Thank you in advance.
Best answer by Abhishek Narulkar
Hi @Ebby
You’ll have to create a secondary copy which will use the new disk library as the storage. Once the copy is created, the Aux Copy Job will then be able to copy over the jobs to the new library.
Extended retention rules can also be defined on the secondary copy.
You can follow this documentation and get more details
https://documentation.commvault.com/2023e/expert/secondary_copies.html
The first what comes to play is obviously an Auxiliary Copy, especially if you just want to send specific, longer retention jobs to new location.
Hi @Ebby
