CommCell environment upgrade with HSX Clusters
  • Feb 3, 2025 10:54 AM UTC
  • 130 views
Hello Team,
I have good experience on Commvault environment upgrade
but I want some advices about HSX environment where I a not very familiar
CommCell version is 11.34.47 End of life target version is latest 11.36
Current HSX Clusters info :
whichCommit.sh
Branch: QBD[v-5.0.8.2]
rpm
hedvig-common-5.0.8.2_3820_f13a4ee0db-1.el8.x86_64
hedvig-cluster-5.0.8.2_3820_f13a4ee0db-1.el8.x86_64
In a standard environment, I update :
1 - Commserve Linux PROD
2 - Commserve Linux DR
3 - Media agents one by one, and I connect to each media agent to perform the update locally not push
4 - Access nodes
5 - Index cache Servers
4 - update clients
I thing for HSX environment it is the same order :
3 - HSX Cluster 1
3 - HSX Cluster 2
4 - Access nodes
4 - update clients
My question is about HSX Clusters update. I am confused about OS upgrade, CVFS update, which order, service disruption during update, anyone can clarify please ?
Thanks for the help !
Best answer by R Anwar
Hi ​@BloopaAgain
CvFS upgrade is done first and then OS RPM’s. However, you are already on latest CvFS version.
I would suggest to plan for migration https://documentation.commvault.com/v11/expert/migrating_hyperscale_x_version_on_existing_nodes.html
R Anwar
  • Feb 3, 2025 4:40 PM UTC
Hi ​@BloopaAgain
