Connect Tape library with HSX
  • Nov 21, 2024 11:19 AM UTC
  • 148 views
Hi Team,
One of my customer having seventeen-node HSX 3.x cluster. They have 12 drive tape library and planning to connect 6 drives out 12 with HSX through to perform aux copy.
Here is my doubt to outline the solution.
  • Do I need to zone all the MA with tape library or only six MA?
  • If six MA, how do I choose those six MA alone?
Can you share your thoughts/inputs.
TIA,
Mani
Best answer by R Anwar
Hi @Mani
Not necessary. You can zone only to X MA's.
Once zoned to specific MA, you can remove others MA's from Data Path of Storage Policy.
R Anwar
  • Nov 25, 2024 11:32 AM UTC
Hi @Mani
