How to connect 3 node HSX cluster to another MA without FC HBA
  • Feb 12, 2025 1:14 PM UTC
  • 89 views
Hi Team,
i have a 3 node HSX cluster and a tape library. unfortunately no FC HBA on HSX nodes.
i want to do Aux Copy the backup from HSX to Tape library. Meanwhile MA to tape libary is connected using FC.
Tape Library MA and HSX are both connected to Commserv , so how we can establish the data connectivity between MA and HSX, and run the Aux copy to copy backup from HSX to Tape
Best answer by R Anwar
Hi ​@Noushad
Tape Library can be connected via FC on the MA’s. You need to install FC cards on HSX node and other physical MA and do AuxCopy.
R Anwar
  • Feb 24, 2025 10:53 AM UTC
Hi ​@Noushad
