HSX OS upgrade from 7.9 to 8.9 with sp32
  • Feb 26, 2024 9:50 AM UTC
  • 16 replies
  • 790 views
we are trying to do OS upgrade the HSX from the existing 7.9 to 8.9 to be able to add additional new nodes (HSX ISO 3.2312)
we tried to upgrade the OS using the Command center and CLI both showing upgrade completes successfully however the OS version is still 7.9
i used the below reference for the OS upgrade operation.
https://documentation.commvault.com/2024/expert/installing_operating_system_updates_on_hyperscale_x_reference_architecture.html
Best answer by R Anwar
Hi @Genny
Doc has been updated now.
https://documentation.commvault.com/2024e/expert/migrating_hyperscale_x_version_on_existing_nodes.html
R Anwar
  • Feb 26, 2024 2:18 PM UTC
Hi @Nawras Haddadeen
Upgrade from RHEL to Rocky has a different procedure. I would suggest to connect with the Account Team who can work internally on this.
Erase4ndReuseMedia
When will the process to upgrade HyperScale X 2.x to 3.x be made available?
  • May 10, 2024 10:59 AM UTC
Considering commvault documentaiton on adding nodes states “You must upgrade 2.x nodes to 3.x version at some point prior to June 30th, 2025.” it would be really useful to have this process available asap considering we are rapidly approaching only a year left to perform this task and I suspect it’s non trivial and will cause interruption to service - especially as doing upgrades to the OS on HSX node (without hedvig update) already requires taking the whole cluster offline.
Forum|alt.badge.img+13
  • Challenger
  • Jul 25, 2024 1:03 PM UTC
I think you need to refresh the cluster node by node
Refreshing HyperScale X Reference Architecture Nodes (commvault.com)
before adding 3.x nodes, a minimum version of 2.2312 is required on existing nodes.
@all, please correct me, if I’m wrong
R Anwar
  • Jul 25, 2024 1:20 PM UTC
@johanningk No need to refresh the nodes.
We should have the process for migration available soon.
  • Aug 19, 2024 12:54 PM UTC
@R Anwar when do you expect the process to be released.
R Anwar
  • Aug 19, 2024 12:58 PM UTC
@mortimor It is expected to be available with SP36. I will update once I can confirm the same.
  • Aug 19, 2024 1:28 PM UTC
@R Anwar
  • Aug 19, 2024 2:33 PM UTC
@R Anwar SP 36 is already available.
R Anwar
  • Aug 19, 2024 2:54 PM UTC
@mortimor SP36 is available but need to check if v2 to v3 migration is available. I will update the thread after a week post confirmation.
Forum|alt.badge.img+5
  • Aug 28, 2024 3:31 PM UTC
@R Anwar Do we have an update on the 2.x to 3.x upgrade procedures?  Also, do you know if there’s a roadmap for support on Rocky 8.10 in the near future?
R Anwar
  • Aug 28, 2024 3:51 PM UTC
Hi @Genny
I don’t see the exact procedure for migration to Rocky. I will need more time to find this.
We will have a new Platform release in Sep which updates to Rocky 8.10.
R Anwar
  • Sep 4, 2024 3:05 PM UTC
  • Sep 5, 2024 4:48 PM UTC
@R Anwar I’m still not seeing docs for 2023E.  My understanding from Products is that the migration procedures would be supported for both 11.32 and 11.36.
R Anwar
  • Sep 6, 2024 4:09 AM UTC
Hi @Genny
Yes, it will work for both SP 32 & 36. ISO is available for both.
  • Sep 10, 2024 10:03 AM UTC
Has someone tested this yet? What is your experiences? We have 11 6node clusters we need to upgrade.
