HyperScale x Installation
  • Jul 27, 2023 10:47 AM UTC
  • 222 views
I have an issue with HyperScale x Installation - I’m installing HyperScale x with 3 nodes
The customer planned to connect all data protection and storage pool to 25g ports
but they doesn’t have all the equipment
Can I connect 2 nodes with 25g port and the last node connect with 10g ports
and in month just change the cables and the SW configuration (after I will put the third node in maintenance)
there is no documentation that address this situation - but it supposed to be OK, right?
 Is there any issue with doing that?
Best regards,
Best answer by R Anwar
Hi @LiorRN
I see TR 230727-336 created for this. Kindly confirm the same and we can work via the case
R Anwar
  • Jul 27, 2023 1:16 PM UTC
Hi @LiorRN
