migrate HyperScale X Reference Architecture 2.x to 3.x
  • Jan 7, 2025 12:24 PM UTC
  • 540 views
Forum|alt.badge.img+2
I am currently going through the documentation to plan the update but some points are not clear to me:
https://documentation.commvault.com/2023e/expert/migrating_hyperscale_x_version_on_existing_nodes.html
Is this paper for both Hyperscale (appliance and RA)?
The migration process migrates and reboots each node in the cluster from RHEL7 to Rocky8 sequentially. This process may take several hours to complete.
Can I continue to perform backups while the cluster is being updated? (I'm thinking of the database log backups)
We have a 6-node cluster, does anyone have experience with the duration?
Michael
Best answer by R Anwar
Hi ​@Michael.B
Yes
Yes, you can do it if the nodes can't be put in meintenance as the node to be upgrade will have services stopped.
It would take ~1.5 Hrs per node
R Anwar
  • Jan 9, 2025 12:13 PM UTC
Hi ​@Michael.B
Yes
