we reimaged hyperscale(reference architecure) using iso,unable to get login prompt to enter username and password
  • December 18, 2023
  • 186 views
Forum|alt.badge.img+2
we reimaged hyperscale(reference architecure) using iso,unable to get login prompt even after <Alt> + <Ctrl> + <F2> at console level
We have 3 nodes,we are able to get login screen on 2 nodes using <Alt> + <Ctrl> + <F2> but on 3rd node,we dont see a login screen
we used ctrl+alt+delete on hot keys as well,it doesnot direct to login screen
Any suggestions
Best answer by Arunkumar P
@bhbekkam  - Glad to hear that you are able to resolve it. But, typing through keyboard also should work.
Press < Alt> + <Ctrl> + <F2> if the login prompt is not displayed.
  • December 18, 2023
we are able to fix the issue by enabling hotkeys in ilo screen
Arunkumar P
Forum|alt.badge.img+9
Hi ​@bhbekkam We are having the same problem, did you manage to fix it?
