Advanced Configuration - Exam portal CSOD
  • April 30, 2025
  • 94 views
Hello, I can no longer access the CSOD portal. I have a voucher for the Advanced Configuration exam.How can I take the test on the Rediverse portal using the same Voucher? It is not appearing on the new portal.
Best answer by Suzanne Klausner
Hi ​@Renildo França, please submit your request to enablement-help@commvault.com so that the registrar team can address this with you.
Suzanne Klausner
Director, Customer Enablement
Suzanne Klausner
Forum|alt.badge.img+8
Suzanne Klausner
