Missing Badges
  • April 28, 2025
  • 104 views
i have completed my certifications in 2022. but badges are missing could you please guide how can i get 3 badges
  • Commvault Foundations.
  • Commvault Advanced.
  • Commvault Engineer.
Thanks in Advance.
cheers,
Bhargava
Best answer by Suzanne Klausner
@Kodali Bhargav you can login to credly.com to see all of your certifications, access your digital badges, and download certificates. Use the “forgot password” link if you need to reset your password. If your email has changed since you received those credentials you might need additional help to reset your account. In that case please reach out to me directly.
Suzanne Klausner
Director, Customer Enablement
Hello ​@Kodali Bhargav
Based on the following previous chat I would recommend raising an email:
enablement-help@commvault.com
Kind regards
Albert Williams
Suzanne Klausner
Forum|alt.badge.img+8
Suzanne Klausner
