CommVault Cloud > SME > AZURE FR36 and Beyond question
  • Dec 2, 2024 9:30 AM UTC
  • 118 views
JosserandM
Apprentice
Hello CV SME Team, can you please tell us if we have plan or release in fo on Azure to protect and restore :
  • Azure KeyVault
  • Azure Devops (repos, pipelines etc)
  • Support Storage Accounts without using Storage Account Services right
  • Automation Accounts
many thx in advance
Best answer by Steve Burkett
Documentation has been updated to indicate that Azure DevOps/GitHub/GitLab support is now available through the Commvault Cloud Early Adopter program.
Onno van den Berg
Forum|alt.badge.img+24
Azure Devops is already supported. Not sure what you mean with "Support Storage Accounts without using Storage Account Services right”, but storage accounts are covered as well. For Azure KeyVault & Automation Accounts you would have to open a CMR.
JosserandM
Apprentice
  • Dec 4, 2024 2:45 PM UTC
Storage Accout : I mean using Managed Identities
DevOps : In metallic ? not seen in the catalog
CMR : OK, there is not road map on this already ?
Onno van den Berg
Sorry, I missed that you raised this question in the Metallic section. No, it is not covered in Metallic, yet.
