Access node - Operating system - Aurora PostgreSQL
  • Oct 23, 2023 12:06 PM UTC
  • 136 views
Hi
We are setting up an EC2 access node in AWS to take backups from our Aurora Postgres estate. We use Amazon Linux 2 for all our EC2 deployments - but it seems for Aurora PostgreSQL its not supported.
Why is it OK for Aurora MySQL but not Aurora PostgreSQL??? It seems a bit odd that the linux OS offered by AWS wouldn’t be supported.
We would prefer to avoid RHEL as it would have cost / license implications (we use RHEL for on-prem deployments) and CentOS is a discontinued Linux distribution. Additionaly RHEL7 is a 10 years old OS that ends maintenance support in June 2024
We are extremely keen to avoid windows because:
(1) It stores Temp files on the access node will taking backup - (we are finding that failed jobs don’t clean up the temp files and eventually fill the temp space) - we want the data to just pass through the node -  and not provision an expensive big EBS volume - we will be backing up multiple TB’s every night
(2) It involves extra annoying configuration from our end to join AD
Aurora MySQL
Amazon Linux 2 on ARM64 (AWS Graviton), x86-64
CentOS 7.x
Red Hat Enterprise Linux 7.x
Red Hat Enterprise Linux 8.x
Windows 2012
Windows 2016
Aurora PostgreSQL
CentOS 7.x
Windows 2012
Windows 2016
Windows 2019
Best answer by Sunil
@Mike Gale ,
You can use Amazon Linux2 and Postgres manually.
Sunil
Sunil
Forum|alt.badge.img+16
  • Oct 23, 2023 12:17 PM UTC
Hi @Mike Gale
Please go ahead and use PostgreSQL Aurora also. It must be a miss in documentation update.
Please refer here for the New features news letter of 2023E release.
https://documentation.commvault.com/2023e/expert/152814_newsletter_for_new_features_in_commvault_platform_release_2023e.html#back-up-and-recover-amazon-aurora-amazon-rds-and-salesforce-by-using-aws-graviton
Sunil
  • Oct 23, 2023 4:07 PM UTC
@Sunil - thanks for the link but there is no mention there of Amazon Linux 2 - it refers to using a commvault AMI  or AWS Graviton based EC2??
Can I use amzon linux 2 and setup the postgres commvault agent manually?
Sunil
  • Oct 24, 2023 12:41 AM UTC
@Mike Gale ,
Sunil
  • Oct 24, 2023 8:32 AM UTC
@Sunil  - Thanks that’s great 😁
