API for Advanced client readiness check
  • Aug 16, 2024 4:21 PM UTC
  • 148 views
christopherlecky
Explorer
Forum|alt.badge.img+21
I am looking for an API call to do an advanced readiness check.
Specifically I want to select the options for the readiness check.
Hello @christopherlecky
Can you confirm what you mean exactly by “advanced” readiness check?
Are you referring to having these options ticked?
If that is the case the following API can achieve all of that:
https://api.commvault.com/docs/SP36/api/cv/ClientOperations/get-client-checkreadiness/#perform-check-readiness
For example if you want “Additional Resources” enabled in the check readiness you can use this flag:
If this is not what you are trying to achieve please share a screenshot of what you are wanting to achieve in the Java GUI and i will see what i can find.
Kind regards
Albert Williams
Kind regards
Albert Williams
christopherlecky
Explorer
This is exactly what I was looking for @Albert Williams thank you.
