Application-Aware Protection for Containerized PostgreSQL
  • August 24, 2026
  • 39 views
ApK
Explorer
Forum|alt.badge.img+8
Hi all.
We have a PostgreSQL server running in a Kubernetes environment, and are looking into how to back this up. We do not backup the Kubernetes environment and have not configured a service account, created a access node as described in the Kubernetes configuration guide https://documentation.commvault.com/11.44/software/configuration_for_kubernetes.html)
I found the Application-Aware Protection for Containerized PostgreSQL documentation (https://documentation.commvault.com/11.44/software/application_aware_protection_for_containerized_postgresql.html), can I use this to backup the PostgreSQL server running in Kubernetes without configuring backup for the Kubernetes environment first?
-Anders
Best answer by Sunil
Hi Anders,
Yes, you can configure this without having to configure K8s backups first.
For this solution, we run Commvault agent inside a sidecar container in the DB pod.
Sunil-
Sunil
Forum|alt.badge.img+16
  • August 24, 2026
Hi Anders,
Sunil-
