Automate commvault deploy
  • Nov 6, 2023 1:21 PM UTC
  • 251 views
Hello!
Is it possible to automate the deployment of commserve with ansible? I would love to be able to bypass the menu prompts with variables when using ./cvpkgadd on linux.
Thanks.
Best answer by Damian Andre
Hi @dtovar22,
Yes - this has been discussed previously here:
You can also create custom install packages with the Commvault installer to automate installation on other servers:
https://documentation.commvault.com/2023e/expert/2027_creating_custom_package_for_unix_linux_and_macintosh_computers_using_installation_package.html
  • Nov 29, 2023 3:24 AM UTC
Hi @dtovar22,
  • Nov 29, 2023 5:27 PM UTC
Hello Damian!
I actually opened a ticket with Commvault support about the specific piece of documentation, the CV support team said they hadn’t heard of anyone using that to deploy a all-in-one commserve installation and essentially said it was for endpoints/clients. Have you heard otherwise?
