AuxCopy Jobs
  • Dec 9, 2024 1:52 PM UTC
  • 84 views
Forum|alt.badge.img+16
i have 3 aux copies to a storage policy , 2 two tapes and one to disk , but for all the aux copies are running under one job id , what setting cause this
Best answer by Wasim
Hi ​@Ajal,
Below is the reference screenshot for you, If you encounter any issue in identifying it, please raise a support case and share the case number. We will assist you further.
Wasim
  • Dec 10, 2024 4:30 AM UTC
Hi ​@Ajal,
It seems you are running the Auxcopy by using the “All Copies” option.
Wasim
  • Dec 10, 2024 5:02 AM UTC
Please verify what ​@Wasim has said and to correct this you can kill run a new job by selecting the appropriate copy or let the next scheduled Copy job to trigger them separately.
  • Dec 10, 2024 5:08 AM UTC
 ​@chrisaj ​@Wasim  the jobs are run on schedule , i have not run it manually , shedule is the default system aux copy schedule ,
multiplexing or combining streams does this ?
  • Dec 10, 2024 5:15 AM UTC
Hi ​@Ajal,
The schedule was configured for “All Copies”. Please create a separate schedule for each copy by selecting the respective copy.
Wasim
  • Dec 10, 2024 5:17 AM UTC
​@Wasim  how do we create a schedule with all copies , there is no such settings in schedules , we associate the secondary copies to the schedule ,
  • Dec 10, 2024 5:26 AM UTC
Hi ​@Ajal,
Wasim
