charging the Commvault and sql installation path
  • Sep 13, 2023 12:39 PM UTC
  • 486 views
Forum|alt.badge.img+16
we need to change commvault ,sql and DB installation path from C drive to d Drive , what is recommended way
Best answer by Nutan Pawar G
 @Ajal
When your Commserve is also a Media agent, there are many other factors that you need to keep in mind before uninstalling and reinstalling.
We need to make sure that DDB, Index Cache and Disk library mount paths are not present under the installation folder. (In your case it is C drive)
If they are on C drive, you need move the DDB and Index cache directory to a new location
With regards to the DDBs, The recommended method here would be to utilize the DDB Move process within Commvault to copy over the DDBs to the new locations. Once this runs and completes we will automatically update the GUI and use the DDB in the new location.
https://documentation.commvault.com/2023e/expert/12582_moving_deduplication_database_to_another_location.html
 Process to relocate the Index Cache to a different location on the same server
https://documentation.commvault.com/2023e/essential/127140_changing_location_of_index_log_cache_directory.html
https://kb.commvault.com/article/80544
@Ajal
Below is the link to change the location of the commserve database files
 https://documentation.commvault.com/2023e/expert/4737_changing_location_of_commserve_database_files.html
In order to change the path of commvault installation path, you need to completely uninstall commvault software and reinstall to the new location.
Note: Please take a DR backup before performing this activity
  • Sep 13, 2023 4:07 PM UTC
@Nutan Pawar G while uninstalling will i loose already backed up data, my commserv machine has media agent as well,
so i will take DR backup
uninstall commserv
install again
restore the DR DB
 @Ajal
