Clean orphan data option instead of manually delete, failed/killed mount path move
  • November 27, 2024
  • 127 views
No special characters
Explorer
Commvault docs say “If the mount path move job fails or is killed, you need to manually clean the data that was copied to the destination mount path.”
Would not “Clean orphan data” do the cleaning?
  • December 2, 2024
Good day.
"Clean orphan data" will help to remove the "Orphan data" only from the active online mount path.
Wasim
