Client group schedule setting
  • Oct 21, 2024 7:44 AM UTC
  • 70 views
I would like to manage the schedule in the client group.
But the schedule doesn't come out
I can check it with Client computer schedule.
Is there a way to manage the schedule in the group?
Best answer by Dheeraj Shetty
Hi @SUHWAN AHN ,
You should be able to view the schedule for that entity (Client/Client Group/Agent/BackupSet/Subclient), if a schedule has been defined at Entity level as outlined in the documentation → https://documentation.commvault.com/2023e/expert/viewing_job_schedules.html
For example, I have created a test schedule with Daily Incr and weekly Fulls and associated to a Client Group ‘ No Backup > 2 Days’
While, you view the schedules at the client group level, it shows the schedules associated with that client Group. If you have schedules defined at the client/agent/subclient level, that wouldn’t be listed in at the Client Group level.
Hi @SUHWAN AHN ,
