Clients without Plans
  • October 30, 2023
  • 76 views
Forum|alt.badge.img+2
We found a few clients that did not have a plan so we were not getting a message that it was
missing backups. Is there a report that would give us this info? or is there a way to know?
Thank you -
Best answer by Kaushik Sharma
Hi @Libi ,
The following reports may help uncover the info you are seeking.
The Subclient Configuration Report may help here: https://cloud.commvault.com/webconsole/softwarestore/#!/135/663/13916
The Data Protection report may also assist with identified the last completed backup: https://cloud.commvault.com/webconsole/softwarestore/#!/135/660/25499
If clients are missing schedules the following report should also help identify that: https://cloud.commvault.com/webconsole/softwarestore/#!/135/660/27713
Kaushik Sharma
Hi @Libi ,
Kaushik Sharma
