CommServeDB - Client Storage Utilization
  • November 15, 2024
  • 101 views
Hello team,
We used the SQL instance to create and customized some reports for our team and clients.
At this moment, I am trying to create a report using the SQL instance of the CommServeDB to build a customized report.
However, I am having some difficulty identifying the table or tables where I can retrieve the capacity used for each storage policy copy.
Can you help?
Thank you!
Pedro Lages.
Best answer by Dheeraj Shetty
Hi ​@Pedro Lages ,
You can use this report “ Client Storage Utilization by Storage Policy Copy” that is available in CV Store to fetch the Data written size of the clients per storage policy copy - https://cloud.commvault.com/webconsole/softwarestore/store.do#!/135/664/13144
Dheeraj
  • July 11, 2025
Hi ​@Pedro Lages ,
We have a ready-to-use report that can help in understanding license usage based on the Storage Policy and Policy Copy.
Kindly run the "License Usage by Jobs" report and ensure that the Storage Policy ID is enabled under the filter section to narrow down the results accordingly.
Kindly let us know if still there is need for SQL Table information.
Hi ​@Pedro Lages ,
Dheeraj
