commvault DR backup retrieving from disk library using MediaExplorer
Hi Expert Team,
End customer environment is secure site. So they cannot whitelist metallic cloud URLs for storing phase1 of DR  backup. Currently the phase1 of DR backup writes to local disk and phase2 goes to commserveDR policy which is HPE catalyst. I believe we cannot recover from HPE Catalyst using mediaexplorer tool(This I read from other community article). We cant even use Network path for phase1.
So we are planning for creating a filesystem backup of phase1 backup folder(SET**) on disk library. If we do this way can we retrieve the DR dump files using mediaexplorer tool? Please advise.
https://documentation.commvault.com/11.40/expert/cataloging_media_using_media_explorer.html
Best answer by Javier
Media Explorer would see those backups are File System, while it is potentially doable, it would be difficult to allocate them due to missing the DR Backup tag.
Why not creating a secondary Aux copy on the DR Policy and copying the Jobs from the Catalyst Storage to regular Storage instead? With this approach you will be able to use Media Explorer on the secondary Aux Copy and the BackupDRs should maintain their tags and jobIDs which will help with their identification.
CV_GK
  • July 21, 2025
Hi ​@AbdulIkram
what is the cs cv version?
version is 11.32.106
  • July 27, 2025
I will give a try if the Aux copy from HPE catalyst to Disk library works.
  • August 5, 2025
Aux copy solution worked. I will test restore using media explorer.I am closing this thread.Thanks for quick help.
