Commvault helm-charts & authcode
  • October 26, 2023
  • 168 views
Onno van den Berg
Forum|alt.badge.img+24
We were thinking to try out the Commvault containers images in combination with Tanzu, but we would like to provision by making use of an authcode instead of username and password. Can't really find if this is possible and which attributes I should use to populate the authcode.
For us it would be ​​​​​​company/commcell auth code. I personally do not see a use-case to use API tokens to add client objects. I already raised the CMR.
Forum|alt.badge.img+9
Hi Onno,
Auth code support is currently not there.
Onno van den Berg
@Amey Karandikar so, I will have to open a CMR for it to be added…… Such a pity that this was missed during the initial build.
@Onno van den Berg  is this company auth code or user api token?
Onno van den Berg
  • Community All Star
  • October 27, 2023
