Commvault supports Redhat open shift or not?
  • Oct 10, 2023 8:39 AM UTC
  • 320 views
Hi Community,
We are confused here, as we are planning to deploy Redhat Open Shift 4.13, we have checked for Commvault support.
We could see the message OpenShift feature is deprecated :
But another document says it will support:
https://documentation.commvault.com/2022e/essential/124720_system_requirements_for_kubernetes.html
Could you please clarify on this and also please share if you have any document for OpenShift setup/Configuration.
Best answer by MichaelCapon
Hi @sauvegarde,
We do support RHOCP 4.13 in FR 2022E (Per the screenshot you shared), We leverage the “Kubernetes” configuration for protecting containerised environments.
Follow the documentation for configuring Kubernetes here: https://documentation.commvault.com/2022e/essential/143051_configuration_for_kubernetes.html
Michael
MichaelCapon
  • Oct 10, 2023 8:47 AM UTC
Hi @sauvegarde,
Michael
  • Oct 10, 2023 9:04 AM UTC
Hi @MichaelCapon,
Thank you for the quick reply and clarification. We will continue our deployement and come back if required :)
Thanks and best regards.
