Commvault Virtualisation features
  • Jul 24, 2023 8:10 AM UTC
  • 145 views
Hi Commvault Community,
Hope everyone is doing well.
I had some questions regarding Commvault support for some Virtualization features, the documentation wasn’t helpful for me, unfortunately.
  1. Does Commvault support “Continuous Data Protection” mode on virtualization platforms ? If so, which vendors it supports.
  2. Does Commvault support instant recovery and power on restore (The VM is power on through backup jobs history and in the background, the VM is being restored).
Please to share with me links to the documentation if there is any, your guidance is much appreciated.
Regards.
Best answer by Rajiv
Hello @Commvault Engineer
If I am not wrong for continuous data protection you meant continuous replication? If yes, this will help:  https://documentation.commvault.com/2022e/essential/106449_vmware_continuous_replication_using_vaio.html
For the second point, I believe you are looking for live recovery, if yes, please find the documentation: https://documentation.commvault.com/2022e/essential/146297_live_recovery_for_vmware_restores.html
Best,
Rajiv Singal
Rajiv
  • Jul 24, 2023 10:14 AM UTC
Best,
Rajiv Singal
Best,
Rajiv Singal
 Thanks a lot @Rajiv.
Actually, I managed to find both links, just wanted to confirm one point, is “Live Recovery” only supported with VMware ? As for Continuous Replication, it’s the case.
Kind regards.
Rajiv
  • Jul 24, 2023 10:37 AM UTC
You are right. We have replications for maintaining the high availabilities further.
Best,
Rajiv Singal
Forum|alt.badge.img+18
  • Jul 24, 2023 3:57 PM UTC
Thank you both guys.
