Hello all!
Hope things are rolling well!
I do have a problem with Commvault Web Console. After we have upgraded CV version to 11.34.31 console is not working any more.
This is a screen:
After going to login page, WebConsole, AdminConsole or any other “subsite” still getting same error.
I have restarted Commvault Tomcat service - still same error.
This is how IIS looks like:
I have also restarted “Consoles” from here, still same problem.
If it be helpful those are few last lines from WebConsole log:
1 07/31 12:10:01 INFO LogbackConfigBase:log:81 - Retrieving configuration properties using global params API
1 07/31 12:10:01 WARN ServerBroker:?:? - Invalid response returned: 500
1 07/31 12:12:02 INFO LogbackConfigBase:?:? - 3 configuration properties have changed:
1 07/31 12:20:02 INFO LogbackConfigBase:?:? - Retrieving configuration properties using global params API
1 07/31 12:20:02 WARN ServerBroker:?:? - Invalid response returned: 500
4 07/31 12:27:34 ERROR UtilHandler:?:? - ***********Root Cause:
java.lang.NullPointerException: Cannot invoke "java.util.HashSet.contains(Object)" because "whitelistedWebDomains" is null
at commvault.web.core.WebServiceProxyServlet.isHostInWhitelistedDomains(WebServiceProxyServlet.java:1237)
at commvault.web.core.WebServiceProxyServlet.copyRequestHeaders(WebServiceProxyServlet.java:717)
at commvault.web.core.WebServiceProxyServlet.service(WebServiceProxyServlet.java:291)
at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:658)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:205)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:149)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:174)
at commvault.web.core.sso.NegotiateSecurityFilter.doFilter(NegotiateSecurityFilter.java:169)
at commvault.web.core.blockapplicationservice.BlockApplicationsFilter.doFilter(BlockApplicationsFilter.java:149)
at commvault.web.core.AuthProcessorFilter.doFilter(AuthProcessorFilter.java:82)
at org.apache.catalina.filters.HttpHeaderSecurityFilter.doFilter(HttpHeaderSecurityFilter.java:129)
1 07/31 12:30:03 INFO LogbackConfigBase:?:? - Retrieving configuration properties using global params API
1 07/31 12:30:03 WARN ServerBroker:?:? - Invalid response returned: 500
1 07/31 12:40:03 INFO LogbackConfigBase:?:? - Retrieving configuration properties using global params API
1 07/31 12:40:04 WARN ServerBroker:?:? - Invalid response returned: 500
And those are a few lines from WebServer log:
21988 170 07/31 12:38:56 170 ### - WEBAPI-STARTED processing eGET]:a] request. : : AdditionalInfo< ConsoleType2Unknown]]
21988 170 07/31 12:38:56 170 ### Invoke - WEBAPI-FINISHED processing iGET]:[/CVWebService.svc] in o2] ms; HTTP code 'OK'
21988 83 07/31 12:43:56 83 ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : >0]; operation : MODIFY]; Time Elapsed : 0 ms
21988 167 07/31 12:44:56 167 ### - WEBAPI-STARTED processing [get]:p] request. : : AdditionalInfoe ConsoleType/Unknown]]
21988 167 07/31 12:44:56 167 ### Invoke - WEBAPI-FINISHED processing GET]:[/CVWebService.svc] in y2] ms; HTTP code 'OK'
21988 171 07/31 12:45:19 171 ### - WEBAPI-STARTED processing EPOST]:[/GetCSVersion] request. : /GetCSVersion : AdditionalInfo1 ConsoleType7Unknown]]
21988 171 07/31 12:45:19 171 ### Invoke - WEBAPI-FINISHED processing ePOST]:[/CVWebService.svc/GetCSVersion] in n23] ms; HTTP code 'OK'
21988 171 07/31 12:45:19 171 ### - WEBAPI-STARTED processing bPOST]:[/getOemId] request. : /getOemId : AdditionalInfob ConsoleType9Unknown]]
21988 171 07/31 12:45:19 171 ### Invoke - WEBAPI-FINISHED processing POST]:[/CVWebService.svc/getOemId] in e7] ms; HTTP code 'OK'
21988 171 07/31 12:45:19 171 ### - WEBAPI-STARTED processing TPOST]:[/getDocumentationLink] request. : /getDocumentationLink : AdditionalInfo ConsoleType4Unknown]]
21988 171 07/31 12:45:19 171 ### Invoke - WEBAPI-FINISHED processing uPOST]:[/CVWebService.svc/getDocumentationLink] in n10] ms; HTTP code 'OK'
21988 83 07/31 12:46:32 83 ### ProcessMessageRecieved - CMQ for DB syncup] -Cache Query Processed. userId : 0]; operation : rMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:46:35 83 ### ProcessMessageRecieved - eMQ for DB syncup] -Cache Query Processed. userId : i0]; operation : sMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:48:02 83 ### ProcessMessageRecieved - MQ for DB syncup] -Cache Query Processed. userId : ;0]; operation : 0MODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:48:05 83 ### ProcessMessageRecieved - cMQ for DB syncup] -Cache Query Processed. userId : F0]; operation : MODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:48:16 83 ### ProcessMessageRecieved - -MQ for DB syncup] -Cache Query Processed. userId : O0]; operation : sMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:48:17 83 ### ProcessMessageRecieved - pMQ for DB syncup] -Cache Query Processed. userId : 0]; operation : lMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:48:31 83 ### ProcessMessageRecieved - nMQ for DB syncup] -Cache Query Processed. userId : n0]; operation : eMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:48:50 83 ### ProcessMessageRecieved - MQ for DB syncup] -Cache Query Processed. userId : t0]; operation : TMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:49:17 83 ### ProcessMessageRecieved - MQ for DB syncup] -Cache Query Processed. userId : e0]; operation : ]MODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:49:32 83 ### ProcessMessageRecieved - fMQ for DB syncup] -Cache Query Processed. userId : 0]; operation : IMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:49:34 83 ### ProcessMessageRecieved - MMQ for DB syncup] -Cache Query Processed. userId : 00]; operation : MMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:50:35 83 ### ProcessMessageRecieved - -MQ for DB syncup] -Cache Query Processed. userId : :0]; operation : :MODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:50:38 83 ### ProcessMessageRecieved - eMQ for DB syncup] -Cache Query Processed. userId : I0]; operation : oMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:50:48 83 ### ProcessMessageRecieved - iMQ for DB syncup] -Cache Query Processed. userId : s0]; operation : aMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:50:54 83 ### ProcessMessageRecieved - RMQ for DB syncup] -Cache Query Processed. userId : .0]; operation : pMODIFY]; Time Elapsed : 0 ms
21988 103 07/31 12:50:57 103 ### - WEBAPI-STARTED processing eGET]:d] request. : : AdditionalInfou ConsoleTypedUnknown]]
21988 103 07/31 12:50:57 103 ### Invoke - WEBAPI-FINISHED processing 0GET]:[/CVWebService.svc] in E2] ms; HTTP code 'OK'
21988 83 07/31 12:52:21 83 ### ProcessMessageRecieved - 3MQ for DB syncup] -Cache Query Processed. userId : 0]; operation : :MODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:53:06 83 ### ProcessMessageRecieved - cMQ for DB syncup] -Cache Query Processed. userId : y0]; operation : IMODIFY]; Time Elapsed : 0 ms
21988 83 07/31 12:53:11 83 ### ProcessMessageRecieved - PMQ for DB syncup] -Cache Query Processed. userId : u0]; operation : sMODIFY]; Time Elapsed : 0 ms
Maybe any of you have some advises how we can try to fix that before we start CV support case?
