Commvault Web Console not working after update
  • July 31, 2024
  • 1723 views
Hello all!
Hope things are rolling well!
I do have a problem with Commvault Web Console. After we have upgraded CV version to 11.34.31 console is not working any more.
This is a screen:
After going to login page, WebConsole, AdminConsole or any other “subsite” still getting same error.
I have restarted Commvault Tomcat service - still same error.
This is how IIS looks like:
I have also restarted “Consoles” from here, still same problem.
If it be helpful those are few last lines from WebConsole log:
 1 07/31 12:10:01     INFO  LogbackConfigBase:log:81 - Retrieving configuration properties using global params API
  1 07/31 12:10:01     WARN  ServerBroker:?:? - Invalid response returned: 500
  1 07/31 12:12:02     INFO  LogbackConfigBase:?:? - 3 configuration properties have changed:
  1 07/31 12:20:02     INFO  LogbackConfigBase:?:? - Retrieving configuration properties using global params API
  1 07/31 12:20:02     WARN  ServerBroker:?:? - Invalid response returned: 500
  4 07/31 12:27:34     ERROR UtilHandler:?:? - ***********Root Cause:
 java.lang.NullPointerException: Cannot invoke "java.util.HashSet.contains(Object)" because "whitelistedWebDomains" is null
    at commvault.web.core.WebServiceProxyServlet.isHostInWhitelistedDomains(WebServiceProxyServlet.java:1237)
    at commvault.web.core.WebServiceProxyServlet.copyRequestHeaders(WebServiceProxyServlet.java:717)
    at commvault.web.core.WebServiceProxyServlet.service(WebServiceProxyServlet.java:291)
    at jakarta.servlet.http.HttpServlet.service(HttpServlet.java:658)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:205)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:149)
    at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:51)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:174)
    at commvault.web.core.sso.NegotiateSecurityFilter.doFilter(NegotiateSecurityFilter.java:169)
    at commvault.web.core.blockapplicationservice.BlockApplicationsFilter.doFilter(BlockApplicationsFilter.java:149)
    at commvault.web.core.AuthProcessorFilter.doFilter(AuthProcessorFilter.java:82)
    at org.apache.catalina.filters.HttpHeaderSecurityFilter.doFilter(HttpHeaderSecurityFilter.java:129)
 1 07/31 12:30:03     INFO  LogbackConfigBase:?:? - Retrieving configuration properties using global params API
  1 07/31 12:30:03     WARN  ServerBroker:?:? - Invalid response returned: 500
  1 07/31 12:40:03     INFO  LogbackConfigBase:?:? - Retrieving configuration properties using global params API
  1 07/31 12:40:04     WARN  ServerBroker:?:? - Invalid response returned: 500
And those are a few lines from WebServer log:
21988 170   07/31 12:38:56 170 ###  - WEBAPI-STARTED processing [GET]:[] request. :  : AdditionalInfo[ ConsoleType[Unknown]]
21988 170   07/31 12:38:56 170 ### Invoke - WEBAPI-FINISHED processing [GET]:[/CVWebService.svc] in [2] ms;  HTTP code 'OK'
21988 83    07/31 12:43:56 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 167   07/31 12:44:56 167 ###  - WEBAPI-STARTED processing [GET]:[] request. :  : AdditionalInfo[ ConsoleType[Unknown]]
21988 167   07/31 12:44:56 167 ### Invoke - WEBAPI-FINISHED processing [GET]:[/CVWebService.svc] in [2] ms;  HTTP code 'OK'
21988 171   07/31 12:45:19 171 ###  - WEBAPI-STARTED processing [POST]:[/GetCSVersion] request. : /GetCSVersion : AdditionalInfo[ ConsoleType[Unknown]]
21988 171   07/31 12:45:19 171 ### Invoke - WEBAPI-FINISHED processing [POST]:[/CVWebService.svc/GetCSVersion] in [23] ms;  HTTP code 'OK'
21988 171   07/31 12:45:19 171 ###  - WEBAPI-STARTED processing [POST]:[/getOemId] request. : /getOemId : AdditionalInfo[ ConsoleType[Unknown]]
21988 171   07/31 12:45:19 171 ### Invoke - WEBAPI-FINISHED processing [POST]:[/CVWebService.svc/getOemId] in [7] ms;  HTTP code 'OK'
21988 171   07/31 12:45:19 171 ###  - WEBAPI-STARTED processing [POST]:[/getDocumentationLink] request. : /getDocumentationLink : AdditionalInfo[ ConsoleType[Unknown]]
21988 171   07/31 12:45:19 171 ### Invoke - WEBAPI-FINISHED processing [POST]:[/CVWebService.svc/getDocumentationLink] in [10] ms;  HTTP code 'OK'
21988 83    07/31 12:46:32 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:46:35 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:48:02 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:48:05 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:48:16 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:48:17 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:48:31 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:48:50 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:49:17 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:49:32 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:49:34 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:50:35 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:50:38 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:50:48 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:50:54 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 103   07/31 12:50:57 103 ###  - WEBAPI-STARTED processing [GET]:[] request. :  : AdditionalInfo[ ConsoleType[Unknown]]
21988 103   07/31 12:50:57 103 ### Invoke - WEBAPI-FINISHED processing [GET]:[/CVWebService.svc] in [2] ms;  HTTP code 'OK'
21988 83    07/31 12:52:21 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:53:06 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
21988 83    07/31 12:53:11 83  ### ProcessMessageRecieved - [MQ for DB syncup] -Cache Query Processed. userId : [0]; operation : [MODIFY]; Time Elapsed : 0 ms
Maybe any of you have some advises how we can try to fix that before we start CV support case?
Hello @Grzegorz
I would recommend an IISReset or a reboot of the server.
If this still does not work then a ticket is the next step.
I also would recommend not being on FR34 as it is our short support release and move to FR36 when you can.
Kind regards
Albert Williams
  • August 27, 2024
Same story here.
Linux commserve 11.32 upgraded to 11.34.37 :
Tomcat_0.log:
2024-08-27 13:10:55.219 SEVERE org.apache.catalina.core.StandardWrapperValve invoke: Servlet.service() for servlet [commvault.web.core.WebServiceProxyHandler] in context with path [/webconsole] threw exception
CommandCenter.log:
 8 08/27 13:21:29     ERROR PlainHttpHelper:getResponse:393 - Exception in getResponse: {}
java.net.ConnectException: Connection refused
at java.base/sun.nio.ch.Net.connect0(Native Method)
at java.base/sun.nio.ch.Net.connect(Unknown Source)
at java.base/sun.nio.ch.NioSocketImpl.connect(Unknown Source)
at java.base/java.net.SocksSocketImpl.connect(Unknown Source)
at java.base/java.net.Socket.connect(Unknown Source)
at org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:75)
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:142)
at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:376)
at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:393)
at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:236)
at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:186)
at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:89)
at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:110)
at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:185)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:83)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:108)
at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:56)
at commvault.web.core.net.PlainHttpHelper.getResponse(PlainHttpHelper.java:342)
at commvault.web.core.net.RequestObject.execute(RequestObject.java:629)
Wrapped by: org.apache.http.conn.HttpHostConnectException: Connect to s54058.dc5.alledc.net:5000 [hostname/IP] failed: Connection refused
at org.apache.http.impl.conn.DefaultHttpClientConnectionOperator.connect(DefaultHttpClientConnectionOperator.java:156)
Command center is down with : Please wait while our servers start up. This may take a few minutes..
