compliance lock for tape
  • February 9, 2026
  • 62 views
downhill
Explorer
I understand that recently compliance lock is available for disk whereas originally it was for S3 specifically. While I don’t see the option to enable it via Command Center, in the console tape copy properties have the Compliance Lock box to check. So my question is - enabling this on tape copies is or isn’t supported?
thanks
Best answer by Orazan
Yes it is supported to enable Compliance Lock for tape copies.  Compliance Lock is a virtual lock which will keep y ou from deleting jobs or adjusting retention for that copy.
Forum|alt.badge.img+18
  • February 9, 2026
downhill
Explorer
  • February 10, 2026
Ok thanks. I guess enabling it from Command Center is expected to come in a future release?
