Copy the contents of a specific tape to a disc library
  • September 30, 2024
  • 147 views
I want to know if it’s possible to copy the content of a specific tape to a disc library ?
Fabrice
Best answer by Abhishek Narulkar
@F@bEDF
You can create a new aux copy within the same policy going to disk and set the “source copy” as the tape copy. The aux copy will read from the tape copy and write to the disk copy.
Creating a Synchronous Copy Using a Storage Pool - https://documentation.commvault.com/11.26/expert/118965_creating_synchronous_copy_using_storage_pool.html
Forum|alt.badge.img+8
@F@bEDF
@F@bEDF
This, although Commvault works at a job work more-so than a tape level. So view contents on the tape, mark down the job IDs associated with the take, and then manually pick those jobs to copy.
  • October 1, 2024
Thanks to both of you for your answers.
F@b
