Could not reach Media Agent [] with hostname
Forum|alt.badge.img+9
Hello Team,
I have issue on my media agent. Services are running and check raidness succesfully. I am unable to browse and restore my backup data  it  failes as Could not reach Media Agent [GAR-PND-PRD-FPS-MA03] with hostname [PGARAPPCVM13]
I have rebooted media agent twice.I have checked the Index cache there is about 900GB free sapce.
Best answer by ETO
Hello I ahve rebooted the media agent again. I guess the index rebuilded it self. It is working fine now
THanks
  • March 9, 2025
Hi ​@ETO,
 Could you please confirm if the Media agent is ready for operation?
Additionally, I would like to know what you are seeing in the CS\Browse log while starting the browse process.
Wasim
  • March 9, 2025
Hi ​@Wasim
Yes Media agent is ready, We are able to take incremental and Full backup. I noticed that Shyntetic Full backup also fails.I have checked CVD logs in the media agent logs. It see some time out about index server. I have rebooted the media agnet again. I could browse the jobs. But Shyntetic backup still fails due to index issue
Emils
  • March 10, 2025
Hi ​@ETO
Can you please confirm the Indexing server used for the client?
You can check this by following:
  1. Navigate to the client properties in the CommCell Console.
  2. Within the client properties, find the 'Index' tab to view the index server details
Confirm the MediaAgent shown in the Index Tab, and ensure the client (PGFKFTPSTA01) is able to reach the MediaAgent shown as the Index server?
Use the cvping command from the client to the MediaAgent on ports 8400 and 8403 to ensure network connectivity using both IP and hostname seen in the commcell and in both direction.
  • March 10, 2025
THanks
