Create a new plan or migrate from SP to PLAN ?
  • October 24, 2024
  • 61 views
Forum|alt.badge.img+5
I already perfomed SP to PLAN migration but I want to know the difference between :
creating a new server plan or converting an existing SP.
Is there some limitations when converting to plan instead of creating a new one ?
Thanks !
Hello @Amin91
The goal of the conversion workflow is to perform a like for like migration of the SP configuration into a plan.
This workflow is a one off operation to be used to move your existing configuration over and once it is complete you should create new plans and not new SP or migrate more over.
Kind regards
Albert Williams
