DataTurbo protocol to Worm copy
  • March 6, 2025
  • 340 views
Forum|alt.badge.img+5
What protocol do you recommend and how to configure worm lock on commvault 11.32. We want to use the data turbo protocol on the OceanProtect x3000. Does commvault support this?
https://documentation.commvault.com/2023e/expert/supported_vendors_01.html
Best answer by Damian Andre
Worm storage lock is only compatible with the vendors listed with the protocols listed. You could try turbo but the documentation specifically lists HyperLock for OceanProtect  - it enables hardware level worm, but you can use compliance lock on any vendor which restricts deletion of jobs, client or lowering retention via Commvault.
